91 apps
17923 jobs
230 users
You don't need to support many architecture and deploy several packages. Your end users can access and use immediately your application.
Based on containers technology, your application can run even several years without the need of any upgrade of your source code. Learn about the technology.
Thanks to our HTTP REST API, you can write your own scripts using our platform. Learn about the API.
